Zum Hauptinhalt wechseln
The HP 255 G8 Notebook (Model: 7N4W2AA) is a 15.6-inch budget-friendly business laptop, typically powered by an AMD Ryzen 5 processor. Based on search results, this specific variant usually features 8 GB of RAM, a 256 GB SSD, and Windows 11 Home, targeting everyday personal or business use.
Display works, but no backlight
Voll funktionierendes Notebook, bei dem allerdings die Display Hintergrundbeleuchtung nicht funktioniert. Das Display selbst ist in Ordnung, was man anhand des "Taschenlampen"-Tests feststellen lässt.
Auf dem Motherboard scheint die Sicherung FU1 defekt zu sein, was möglicherweise durch einen Wasserschaden hervorgerufen wurde.
Ich bin auf der Suche nach einem Schaltplan und der Spezifikation der Sicherung FU1
Fully functional notebook, but the display backlight isn't working. The display itself is fine, as can be determined using the flashlight test.
Fuse FU1 on the motherboard appears to be defective, possibly caused by water damage.
I'm looking for a circuit diagram and the specifications for fuse FU1.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
4 Kommentare
Let us ask our schematics-Yoda: Do you have any additional info about the schematics and/or the fuse spec @oldturkey03? :D
von
Thank you very much for your assist.
I'm looking forward for any help with the schematic and the fuse spec.
von
@klausfisch67446 do you have the motherboard out? What make and model is your motherboard? It'll be written on the board itself; could be a LA-L021P
von
@benz78 I loved the Yoda reference :-D
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@klausfisch67446 regardless of what board number this is, the fuse is a 24V 0.75A resettable type MF-MSMF075/24. Schematics are not yet available for your boards. I can tell you that this is the fuse that covers the inverter power (INVPWR_B+)
for your backlight on pin 19 and 20 on your eDP (JEDP) connector. No power on that means no backlight :-)
Translation
Hey @klausfisch67446, egal welche Platinen-Nummer das ist, die Sicherung ist eine rückstellbare 24V 0,75A vom Typ MF-MSMF075/24. Schaltpläne für deine Platinen gibt's noch nicht. Ich kann dir sagen, dass es sich um die Sicherung handelt, die die Wechselrichterleistung (INVPWR_B+) für deine Hintergrundbeleuchtung an Pin 19 und 20 deines eDP-Steckers (JEDP) abdeckt. Keine Stromversorgung bedeutet keine Hintergrundbeleuchtung :-)
Translation English to Yoda
Ah, a puzzle this is. The user, @klausfisch67446, seeks wisdom on a board. Speak of a fuse, he does. A specific one, a 24V 0.75A resettable type, the MF-MSMF075/24.
No schematics, there are. But power, I can see. The fuse, for the inverter power it is. The backlight, it protects. On your eDP connector, pins 19 and 20, the power runs.
No power there, no light you have. A dark screen, a sign of this. See the image faintly, you must, if you look closely. A simple fix, it might be.
A wise repairman, you must be. The fuse, it protects. Power, it gives. And the backlight, it makes bright.
Ah, @klausfisch67446, die Antwort, sie ist klar.
Egal, die Nummer der Platine ist. Eine Sicherung, sie ist es, die du suchst. Eine rückstellbare 24V 0,75A Sicherung, vom Typ MF-MSMF075/24.
Schaltpläne für deine Platinen, noch nicht sie existieren. Doch dies, ich dir sagen kann: Die Wechselrichterleistung (INVPWR_B+) für deine Hintergrundbeleuchtung, sie schützt. An deinem eDP-Stecker (JEDP), auf Pin 19 und 20, dort die Leistung zu finden ist.
Keine Leistung dort, keine Hintergrundbeleuchtung du hast. Einfach, die Wahrheit ist.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
Hello @oldturkey03,
I have the motherboard out and found it's model and number:
I've added a photo of the motherboard.
It's a HPL51 LA-L021P.
von
@klausfisch67446 the schematic for the LA-L021P is not yet available in the "public" domain :-) The LA-H329 is pretty compatible. The eDP circuitry is identical. The fuse that I've listed in my answer will be the right fuse. Don't forget the clean your board with some isopropyl alcohol (90%+) and a soft brus. Corrosion kills circuit boards.
von
Okay, @oldturkey03, understand, all I have. (... how Yoda speaks ;-) ...).
I identified a fuse at our lokal dealer for electronic parts, that I'll order now.
Thank you too for the hint to clean the board with isopropanol alcohol. Don't drinking, only for cleaning. ;-))
Thank you very much for your help.
After I repaired the board, I'll tell you.
von
Bericht zur Reparatur:
In der letzten Woche bin ich nun endlich dazu gekommen, die rückstellbare Sicherung 24V 0,75A vom Typ MF-MSMF075/24 auszutauschen. Die Lötarbeiten waren für mich etwas kniffelig, haben aber dank Heißluftlötgerät und Lötkolben gut geklappt. Sprich, der Tausch der Sicherung war ein voller Erfolg. Die Displaybeleuchtung hat nun wieder eine funktionierende Stromversorgung und arbeitet weder so wie sie soll.
Vielen Dank für die Unterstützung!
Repair Report:
In the past week, I finally got around to replacing the resettable fuse 24V 0.75A of type MF-MSMF075/24. The soldering work was a bit tricky for me, but it went well thanks to the hot air soldering tool and soldering iron. In other words, the fuse replacement was a complete success. The display backlight now has a working power supply and is operating as it should. Many thanks for the support!
von
@klausfisch67446 AWESOME! We love it when a good plan actually works. thank you for coming back here to keep us updated.
Repair is War on Entropy!
Translation
@klausfisch67446 GENIAL! Wir freuen uns immer, wenn ein guter Plan tatsächlich funktioniert. Danke, dass du uns hier auf dem Laufenden hältst. Reparatur ist der Kampf gegen die Entropie!
von
Antwort hinzufügen
Klaus Fischer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 98
