Zum Hauptinhalt wechseln
Eine dritte Version des Controllers wurde im November 2020 zusammen mit der Xbox Series X und Series S veröffentlicht. Dieser Controller ist abwärtskompatibel mit früheren Xbox One-Konsolen und PCs.
How can I remove stuck pin?
Pin is mushroom at the top, meaning no grip, but at the bottom it has grip. I used a desoldering gun and wick still didn’t work, so I got a hot air station. Still doesn’t work. Temperature I used was 300-400°C for 15 seconds or more, but it depends. Solder is lead-free.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
Hi!
Are you able to upload some photos? This will make it easier for us to come with an answer! Thanks!
von
Mybad updated picture uploaded
von
@dan0, for equipment, I have an atten heating station, a Hako desoldering gun, and a soldering iron Hako 8888DX.
von
Thanks! Do you have a hot air station? Would try that and then try with tweezers to get it out. Make sure you use flux first. It should come out.
von
Einen Kommentar hinzufügen
1 Antwort
I would add flux and then solder, heat, and try to pull with tweezers. Might need to increase the heat as well. Hope this helps.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
I tried using that method to increase the temperature, but nothing happened. Is there a way I can demonstrate it to you on FaceTime?
von
I’m thinking about getting a another daughter board but at the same time what if that issue come up again
von
Antwort hinzufügen
randy 098 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 157
