Zum Hauptinhalt wechseln
Apples Flaggschiff-Smartphone für 2020 wurde am 13. Oktober angekündigt und kam am 23. Oktober auf den Markt. Dieser Nachfolger des iPhone 11 Pro ist mit einem 6,1 Zoll OLED Display, einem Kamerasystem mit drei Objektiven und LIDAR sowie 5G ausgestattet.
Reattach/replace lightning connector?
Connecting lightning cable doesn’t always charge. It feels like something is loose in there. And when it doesn’t connect, a good smack of the phone downwards into my palm can do the trick. Also, the lightning cable can just kind of slip out, like it’s not catching in the receptacle.
So, what do you think is going on?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Given that the lightning connector is the hardest working part of the phone, generally being plugged and unplugged at least once a day if not more, it stands to reason if anything is going to wear out, it's going to be that plug.
Based on your description, it really sounds like your port has seen better days and should be replaced. I'm assuming here that you've tried all of the non-surgical remedies such as trying a different cable and cleaning and inspecting the port for any damage or obstructions like lint or dirt build up inside.
Unfortunately, iFixit doesn't have a guide to that repair, but the Spanish site Nadie Me Llama Gallina has just what you need. As you might guess, the site is in Spanish but does have an English language option.
Manuales / Apple iPhone 12 Pro / Load flex - Nadie Me Llama Gallina
I would definitely recommend replacing the port, which should get you fixed right up. If you want to support iFixit's repair efforts, you can purchase the part you need right here on this site.
iPhone 12/12 Pro Lightning Connector Assembly
If you're a bit more cost conscious, you can also find it on the major retailer sites like eBay, Amazon and AliExpress, plus a host of other places that specialize in phone parts.
Replace a lightning connector assembly compatible with an iPhone 12 or 12 Pro. Includes the flex cable, logic board connector, lightning connector socket, and one microphone. Part #821-02627. Bild
Produkt
$26.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
kara07 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 76
