Zum Hauptinhalt wechseln
Reparaturanleitungen, Support und Problemlösungen für das 2022er 13-Zoll MacBook Air, ausgestattet mit Apples M2 Chip. Erscheinungsdatum 15. Juli 2022, Modellnummer A2681
Looking at buying a system with a broken screen
I'm thinking of buying a macbook air M2 with broken screen to use it headless and want to know if it's going to work or not?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Sadly the newer Apple laptops really can't have its display removed without creating other problems. Here Apple integrated sensors within the display lid and its associated logic monitoring a collection of sensors and data signals for system health monitoring via the SMC logic. When you alter things as drastically as removing the display things can break!
Without the display lid present the system can't tell if the lid is up or down to then alter which display is the primary, the SMC logic also will throttle the processor logic due to thermal input error as the display thermal sensor is missing.
OS updates won't install properly as the display ID is not seen as it's now missing.
Using a system with a damaged LCD panel is still possible! Here you use the system in what is called Clam Shell Mode!
How do I activate clamshell mode with extended external display?Use an external display with your MacBook Pro] jump down to the After you have connected your display section.
Replacing the display is not cheap! Here's a link to the Apple repair manual MacBook Air (M2, 2022) Repair Manual where you can find the display assembly P/N to then order it from Apple via their Self Service support site. As you will need to access their paywall calibration site to complete the repair.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Ahmed Nageeb wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 59
