Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2016. Modell A1534, EMC 3099. Jetzt mit schnelleren Kaby Lake Prozessoren bis zu 1,4 GHz Core i7 mit Turbo Boost bis zu 3,6 GHz und bis zu 50 Prozent schnellerer SSD und unterstützt bis zu doppelt so viel Speicher.
MacBook is taking power but is not turning on
I bought this MacBook knowing that it didn't turn on. Now I'm under the hood, the light next to the battery disconnect is lighting up, but still no boot. When I plug it into power without the battery connected, the light comes on, but still nothing. The area around the keyboard warms up like my working MacBook Pro when charging. The MacBook is taking power but is not turning on. I've checked the charge port (no physical damage), all the ribbon cables (also no damage), and still nothing. Could it be the actual power button? Idk what to check next.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
To diagnose you'll need a USB-C power meter which you put inline with your charger so you can monitor the voltage level. Here you should see a voltage change as the charger is handshaking with the system to determine the required voltage. If that is not happening the power logic needs repair.
As far as the Power Button is not easy to get to at you need to short across two of the contacts of the keyboard cable connector basically emulating what the switch does. Check the power first. You'll want to get the schematics and board view drawings to locate the pins you need to short out.
War diese Antwort hilfreich?
Bewertung 1
@bve45 we need to actually see your logic board. To check your power button, apply a jumper (use something like a screwdriver) across the two contacts shown, to turn your laptop on. On the keyboard connector itself, it will be pin 22 to ground. Now, you should still check the power etc. if it does not come on.
Bilder zu einer vorhandenen Frage hinzufügen
Bewertung 1
2 Kommentare:
I tried the debug "buttons" and that did nothing, both with the battery connected and not
von
@bve45 that means your board is not turning on. now it's your turn to check thigs out further. Contact me by email if you need the boardview and schematic
von
Antwort hinzufügen
Ben wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 205
