Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Das Modell A1238 / 80, 120 oder 160 GB Festplatte / schwarzes oder silbernes Metallfrontteil
1016 Fragen Alle anzeigen
Is there a way to distinguish "thick" and "thin" by model #?
Looking for a way to identify the "thick" 160GB Classic by model number or serial number, without measuring.
Trying to buy "thick" Classics on-line, without having to have seller measure iPod.
I think the difference is only about 0.1"
Beantwortet! View the answer Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Kommentare:
thanks for the help.
von
They no longer offer this option for iPod classics - this doesn't work. The tech I spoke to thought I was crazy thinking there were 12 different models.
von
Einen Kommentar hinzufügen
EINFACH ALLE TABS ÖFFNEN
RAM Upgrade Kits für Mac
Kits kaufen
Genügend RAM
für alle Tabs
Kits kaufen
3 Antworten
Gewählte Lösung
Unfortunately, there is no distinction in model number between the thick and thin 160 GB Classics.
The best way I have found to distinguish them without opening it up is to do the following:
  1. Locate the serial etched on the rear panel of the iPod.
  2. Go to Apple's Online Service Assistant and enter your serial number and country.
  3. Look at the text under the picture on the left. If it reads "iPod Classic," you have the thick version. If it reads "iPod Classic (Late 2009)," you have the thin version.
Good luck!
War diese Antwort hilfreich?
Bewertung 11
Kommentare:
Thank you for your answer. i have a thin ipod.
von
Brilliant, thank you for this :)
Also just to add to above, if you look on back of Ipod and it says Model: A1238, then it is a thin, 2009 version (aka 7th generation). On older models the last three characters of the serial number will be one of these: Y5N, YMU, YMV, or YMX.
Ben's link above no longer works but see here:
https://support.apple.com/en-gb/HT204217
von
Ignore the comment saying A1238 is the thin model. A1238 applies to the 5th Gen (2005) through the 7th Gen (2009). As it states above, the model number doesn't show if it's thick or thin. Check the serial number on Apple's support page.
von
I found one is slightly heavier 5.7ounce~163g for thick 4.9 ounce ~137g for thin
so iweighed mine with a digital kitchen scale to find out
also see below link
http://www.everymac.com/systems/apple/ip...
thanks..
Bewertung 5
Kommentare:
Thank you for your answer. I have weighed my and it is a thin ipod.
von
Mines 160g so close enough to call it the thick one. Thanks.
von
take a look at everyiPod.com
The distinct model numbers are listed there for the original (thick) and Late 2008 (thin) models of the Classic 160GB (there are also different model numbers for silver and black variants)
you can also try the model lookup page on the same site.
Bewertung 3
Antwort hinzufügen
mahonken wird auf ewig dankbar sein.
Statistik anzeigen:
Letzten 24 Stunden: 12
Letzten 7 Tage: 67
Letzten 30 Tage: 355
Insgesamt: 32,314
