Zum Hauptinhalt wechseln
The Samsung RF34H9960S4 is a French Door Refrigerator with a 33.9 cu. ft. capacity, featuring four doors, a FlexZone Drawer with adjustable temperature settings, a Twin Cooling Plus® system, and a dedicated Beverage Center. This model also includes LED lighting, Power Freeze and Cool options, and a door alarm for added convenience.
Lightning hit my house and now my refrigerator flashing Error Code C66
Samsung Refrigerator RF34H9960 Touchpad not responding. Error C 66 Flashing and all normal cooling. Ice machine works and water also works. All light works. Touchpad wouldn’t respond. Also bought brand right bottom touchpad and still flashing Error Code C 66. I tried unplugging the refrigerator and waited for a week to make sure the error code would reset but still flushing error code C 66.
Update (10/07/25)
Hi,
I bought brand oem Samsung chef Refrigerator Rev. 08
MODEL CODE : RF34H9960S4/AA mainboard and replaced with the newer one and error C66 is still flashing. The touchscreen still wouldn’t respond.
Tried to press all buttons and non responsive.
I also replaced the freezer right side touchscreen with newer oem parts and still no . Ice machine works, the backing fan works fine and ice buildup.
THANK FOR ANY HELP.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @ibrahimmoh71249
On p.75 of the service manual it shows that error code 66 indicates a door handle heater open error.
The manual describes how to test where the problem is. See p.110 for the location of the CN51 connector on the mainboard
Looks like the lightning strike not only took out the touchpad, but possibly the heater element/element power circuit as well
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Hi
thank you for answering.
Where is the location of the CN51 connector on the mainboard. Which side if the Samsung Chef Refrigerator to find the mainboard?
Thank you
von
@ibrahimmoh71249
The information is in the service manual I linked in my answer
See p.35 for the board location and p.110 for where the CN51 connector is located.
von
Any update on this issue? I have the same problem and tried the steps in the manual with no success. I also cannot find in the manual where the actual heater is located. It says door but there are 4? I am to assume the heater it is referring to is the auger assembly for the ice maker as this is the only heater I can think of.
von
@christophe73323
Here's a link that shows where the heater is located. (I think). It is a cord heater designed to fit inside the handle.
von
Antwort hinzufügen
Ibrahim Mohamed wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 28
Insgesamt: 258
