Zum Hauptinhalt wechseln
Das Google Pixel 2 ist Googles zweites Flagschiff -Smartphone, es erschien am 17. Oktober 2017. Das Smartphone ist mit einem 5" AMOLED Display ausgestattet und kann mit 64 oder 128 GB Speicher bestellt werden. Erhältlich ist es in drei Farben: Schwarz (Just Black), Weiß (Clearly White) und Blau (Kinda Blue).
Display faulty after battery replacement - found connector damaged
I replaced the battery of my Pixel 2 after the iFixit-instruction.
After reassambling the display behaves odd - display is very dark, and if I slide the brightness settings slightly higher, the display gets very greenish and I see a lot of display shifts and artifacts.
I tested it with anoter display on same device - does not work.
I tested both displays with anoterh px2 device - there it works.
I had a look with a microscope (at my company) around the display connector, and noticed that two tiny components are clearly missing (solder points broken out), which most likely happened during removing of the display connector.
Could this be the reason?
Now the questions:
  • which components are at this location?
  • Can I buy replace?
  • How or who can I could solder it onto the board? I have no special solder equipment for this purpose (only a good microscope at work...).
The chance to find these broken components on my desk is very small (or nearle 0%).
Any ideas?
my damaged:
original:
display artifacts (greenish, to dark, pixel shifts):
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
capacitor and either a resistor / filter. requires microsoldering skills to replace them
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Robert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 69
