Zum Hauptinhalt wechseln
Der DualShock 2 Analog Controller erschien erstmals mit der PlayStation 2 und wies nur geringfügige kosmetische Änderungen auf, etwa bei den Positionen der Schrauben.
both analogs are sqeaking and glitched.
even when analogs are centered, the input is as if its going straight down-right.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I did have a controller that did this as well. The first step is to take apart the controller using the IFIXIT guide. The first thing I would recommend doing is spraying a light amount of compressed air into the analog stick. This is what fixed the controller for me. Next, I would take a cotton swap and clean up all of the old residual lubricant and replace it with electronics safe WD-40. If that works, then great! If not you will probably have to replace the joysticks. You could order a decently cheap pair of analogs from this link PS2 Analog Sticks (or any other ones like this). There is also a guide on how to replace these on IFIXIT.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
thanks kind sir, i havent tried it yet but ill let you know when i do. 🙏
von
Antwort hinzufügen
Yassin Sherif Saleh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 10
Insgesamt: 120
