Zum Hauptinhalt wechseln
Reparaturanleitungen und Informationen über Demontage sowie Problemlösung für die Nintendo Switch 2, der mit viel Spannung erwarteten Nachfolgerin der originalen 2017 Nintendo Switch. Angekündigt am 16. Januar 2025, offiziell herausgekommen am 5. Juni 2025.
How do I safely remove the anti-shatter film?
I'd like to remove the plastic film that comes applied to the console. I know nintendo said not to remove it, but it scratches so easily (mine is already scratched) and it gets all smudged by fingerprints - basically, it's awful.
I am hoping that by removing it, the scratches will go with it. I can then add a tempered glass screen protector afterwards
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi!
What do you mean with the anti-shatter film?
You can't remove any layer (that is pre-applied in the factory) from the screen...
You probably need to replace the touchscreen to get it "scratch free" at this moment.
Tempered glass should have been applied before it was scratched.
Sorry!
War diese Antwort hilfreich?
Bewertung 0
4 Kommentare:
Hey, thanks for the quick answer.
There is a thin plastic layer pre-applied to the screen that is meant to prevent glass fragment scattering in case of damage. Some people have had success in removing it and adding a glass protector afterwards.
von
Ah sorry, yes the Switch 2 does come with a factory installed "protective screen layer". Same as for the OLED's. The thing is, that it's recommended to place a new screen protector or tempered glass protector over it! Anyway, if you wish to proceed to replace it, you can watch this video: https://www.youtube.com/watch?v=tELAMWhX... (at 3:00 you can see how he removes it).
Please let me know if you have any questions!
von
No problem in remove the film I removed in the oled and the switch 2 with no problem . Simple use some hairdryer and with your fingernails Pell off the edges and continue with the hairdryer still it came off completely .
von
Glad that it worked :)!
von
Antwort hinzufügen
Bejn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 69
Letzte 30 Tage: 303
Insgesamt: 1,516
