Zum Hauptinhalt wechseln
Informationen zu Reparatur und Demontage des Samsung S22 Ultra Smartphones, das im Februar 2022 auf den Markt kam.
What component is this and what does it do
Update (10/05/25)
Update (10/05/25)
Galaxy note 20 ultra motherboard
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
The pic I posted is from a galaxy s22 ultra the capacitor broken off so the device boot and show the Samsung logo for some seconds and then goes black and power off. am looking a replacement capacitor. Can I get a replacement from another device motherboard like a galaxy note 20 ultra or any other device
von
[image|3791636][image|3791638][image|3791637]
von
My donor galaxy s22 motherboard. See pics
von
@blazeink what other boards do you have. I do not have the parts list for the S22 board.
von
Good morning. My galaxy s22 ultra wifi not working. I sent a pics of the issue but Bluetooth working find. Need you help in solving this issue [image|3850248]
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@blazeink that is reference designator C24042 which is a 120PF 10% 25V X7R capacitor in a 0603 package.
Update (10/05/25)
@blazeink that board does not have the same capacitors but it does have a 270PF capacitor which you can use. Replacement capacitors with a higher capacitance can be used for as long as the values are never lower than the original. It is C9126 To find it you will need to remove the EMI shield
and then you will find the capacitor in the location as outlined by the blue arrows.
War diese Antwort hilfreich?
Bewertung 0
11 Kommentare:
Capacitors like that are typically used to smooth out fluctuations in the power inputs to various components; they're placed very close to whatever part they're protecting.
von
The pic I posted is from a galaxy s22 ultra the capacitor broken off so am looking a replacement can I get a replacement from another device motherboard like a galaxy note 20 ultra
von
@blazeink yes you can for as long as it has the same value. I am not sure why you would do that. These capacitors are a "dime a dozen " and really inexpensive. Now, if you have a board laying around that you want to use as a donor board, we will need to know exactly what board you have.
The capacitor is part of your battery circuit so yes, it could be causing the issue.
von
I have a galaxy s22 donor board
von
I all so have other samsung boards
von
6 weitere Kommentare anzeigen
Bildinhalt anzeigen:
Bewertung 0
2 Kommentare:
Wifi not working
von
@blazeink same phone? What have you tried? What have you checked?
von
Antwort hinzufügen
blaze ink wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 29
Insgesamt: 249
