Zum Hauptinhalt wechseln
Chrysler debuted the 2008 model year Town & Country went on sale on August 16, 2007 as a 2008 model.
Why my steering wheel is shaking once my speed is above 50 miles
Why my steering wheel is shaking once i reach 50 miles and above
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
First Check your tires are balanced. (Cheapest easiest fix)
Then check alignment as well as damage to the wheels. Next cheapest fix.
Other possible causes: (More expensive repairs, sorry)
Worn suspension parts such as ball joints, tie rods and wheel bearings can cause your symptoms.
Bent axles or wheels (from hitting curbs or potholes hard)
If it only happens when you use your brakes it may be due to warped rotors or imbalanced brakes.
Good Luck.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Regan Dacayo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 29
Insgesamt: 37
