Acer nitro 5 AN515-58-58NF Will not power on
Woke up one morning and my laptop will no longer turn on. When I push the power button the keyboard lights up and the fans kick on, strong at first then slow down. Then nothing. The screen doesn't come on, error beep codes or anything. I tried waiting a bit then hitting the caps lock button to test if it's just the screen and have also tried to connect a hdmi and key command to a different screen and nothing. From here I opened it up and tried reseating the RAM. Nothing changed. I then tried removing the RAM and powering on the laptop to see if anything different happens and still nothing. I have also tired disconnecting the battery and cmos then holding the power button to reset everything. Everything I've tried has made any difference. There was a little dust in the fans nothing out of the ordinary and no visible signs of internal or external damage. At this point I think its something in the BIOS or motherboard. Anyone have any suggestions from this point?
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Hey it’s been a bit but did you find a solution to your problem, I have the same laptop as you (an515-58-5046) and i’m experiencing the same problems except mine the lights don’t even turn on anymore or the fans just the light for my battery charging indicator and the power button one next to it. Did it happen to be a motherboard problem?
von
Einen Kommentar hinzufügen
