Zum Hauptinhalt wechseln
Reparaturanleitungen, Demontage und Informationen zur Fehlerdiagnose für den Sony PlayStation 5 DualSense-Controller der ersten Generation, Nachfolger der DualShock-Serie. Identifiziert durch die Modellnummer CFI-ZCT1W und das Motherboard-Modell BDM-010.
Controller's board is flashing yellow 3 times when connected to power
Hello! Newbie here, I tried to replace the analog sticks on my PS5 controller as it had stick drift. After a long ride, I finally got the new modules installed and soldered to the board. I wanted to check if it still works and plugged the battery in. The LED on the front flashed 3 times in yellow color. There is another similar question here and, people are saying it is a short circuit. Is this board dead? Or can I do something to fix this issue?
Thank you!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hello Paul, did you put the controller fully back together when you tried to test to see if it still works? The 3 flashes in the yellow color can mean different things.
1st answer- 3 yellow/amber led flashes- The controller is going into rest mode it’s disconnected or the PS5 has entered sleep mode.
2nd answer- Controller can’t connect — could be low battery, no Bluetooth sync, or firmware crash.
could you provide me some more details please.
War diese Antwort hilfreich?
Bewertung 0
6 Kommentare:
I didn't fully put it back together, just plugged the battery in the board and then connected it to my laptop via usb c to check the calibration tool. It is not showing up on my pc, it did show up prior to changing the analog modules.
von
There's your problem!
• The battery provides power, so the microcontroller wakes up.
• It quickly performs a self-check.
• When it sees missing connections (like the USB board, touchpad ribbon, or trigger lines), it flashes yellow 3 times and shuts down to protect itself.
Go ahead and put it fully back together and then test it.
Get back to me if it works
von
@carsons45505 Thank you! This didn't work for me, in the end I desoldered it and soldered everything again. Now it works like a charm, appreciate your help!
von
Well, I got same issue for no reason suddenly it start flashing 3 times every time i press the power, plug the usb or even charging using the dock … after flashing nothing happened. I tried another battery but problem persist… I tried to disassemble everything… no ribbon cable is connected… only the board ( with analog sticks) and the 4 wires for the vibration motor but no success … reconnecting all ribbons ( trigger and touch pad) again but no success … any suggestion please!
von
Update!! .. I found 2 defected capacitors close to the power IC that causes the problem 😩
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Paul Clodnischi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 87
Letzte 30 Tage: 412
Insgesamt: 2,518
