Zum Hauptinhalt wechseln
Das DS Modell ist die siebte Generation der Spielekonsolen von Nintendo.
Ds does not show anything black and light is green
So I just started my DS after I replaced the outer shell and inside shell and now it stopped working like it just shows black screens what I turned on and the light is green and I tried to find some you know shortage and Wi-Fi chip because I know that in the Wi-Fi chip, there’s the bios and firmware, but I couldn’t find anything so if someone could help because he had the same problem and fix it please send me the guide and how to fix this. I want to fix my ideas without going to the repair shop.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi!
Yeah, usually caused by the WiFi chip!
The only thing is, is that the WiFi chip is soldered on the motherboard for the DS Original.... So if you have a lot of experience with soldering, you can do it by yourself, otherwise I would go to a local repair shop to get it fixed.
Please make sure that all the ribbon cables are connected as they should be. Just to be sure!
I couldn't find a guide for this one, sorry! It's actually taking out the motherboard and then de-solder the WiFi chip, and solder the new one in. It's not easy to do, to be honest..
Please let us know how it goes!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
hey so i already fixed it but i didnt even needed to buy a new card i just desolder the cover and it is working fine now but thanks
von
Ah! Glad that it works now, and even without a new WiFi chip! Maybe a cracked solder joint there somewhere. Or the cover caused a short, somehow! Anyway, glad that it's working now!
von
Antwort hinzufügen
Martin Servis wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 47
