My samsung is bloated speaker and charging port not working!
What the problem and what should i fix and how much i hope i get notice because i only have 18% thank you so much!
Ist dies eine gute Frage?
By "bloated" if you mean is is 'swollen' the battery is bad and you should replace it as soon as possible, continuing to use it with a swollen battery may cause severe damage to the phone. The problem with the charging port is probably that the battery's internal resistance has gone up due to bad cells and if you keep charging it or using it, it may even catch fire.
Probably not, but it has happened. Sorry, get a new battery and dispose of the old one properly. You can probably leave it with the shop where you buy a new one. The speaker might have been damaged by the bad battery, hopefully not.
Good Luck.
War diese Antwort hilfreich?
@Juan Garcia Thank you so much!
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 19
Insgesamt: 186
2 Kommentare
The battery is BAD and MUST be replaced As soon as possible, stop trying to charge it, you may end up with it causing more damage to the phone.
von DanJ
@danj OMG! Thank you so much!! THIS HELP ME VERY WELL!
von Marc Dela Cruz
