Zum Hauptinhalt wechseln
Repair and disassembly guides for garage door openers.
Sears garage door opener 139.536738SR3
The opener no longer works with remotes and only closes when you hold the mounted door bell button. I disconnected both sensory wires on the back of the opener meaning they should not come into play. unfortunately I still must hold the button to get the door to close. No shorts in wire running from door bell to opener and hooked up properly to #1 and #2 screws…..HELP.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @donpotratz
Have you tried reprogramming the remotes, you didn't say?
If not, see p.33 of the user manual for the procedure.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Don potratz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 19
Insgesamt: 96
