Zum Hauptinhalt wechseln
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Fragen Alle anzeigen
Replace LCD or just inverter on iMac 20"?
My iMac 20" (Core 2 duo A1207, 2.16 GHz) LCD screen suddenly became grey developed vertical and horizontal lines (see image). There is also what looks like a crack on the top left corner where there is a white patch.
The computer works fine otherwise on a secondary monitor (I am actually using it now)
The question is whether I need to replace the entire LCD or just the inverter?
How long do these screen last? I have had the computer for 6+ years.
Does nt look like it will be worth replacing it with a new one considering how much they cost. any ideas on where I can get a used replacement (I live in Sweden)
Update
Thanks. The screen is not dim a such, most of it is actually white with horizontal grey bands and the vertical green/red/black lines on the left that start from what looks like a crack mark on the top left as you can see on the attached image.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
2 Kommentare
This question was migrated from http://meta.ifixit.com/Answers.
von
Apple iMac "Core 2 Duo" 2.16 20-Inch Specs
Identifiers: Late 2006 - MA589LL - iMac5,1 - A1207 - 2118
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If the screen has dimmed but you can still see the desktop, replace the inverter. I did not see a link to your image.
Inverter is Apple part# 661-4112
Samsung LCD 661-3895
LG LCD 661-3881
War diese Antwort hilfreich?
Bewertung 3
Failed LCD panels are a known issue on the white Intel imacs. It is DEFINITELY the LCD that is bad if you have vertical lines on the screen.
Bewertung 0
Antwort hinzufügen
kuria wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 2,365
