The engine loses power and stalls
Hello everyone,
I own a Jaguar S-Type, model year 2002.5-2003, VIN M55376.
The car has a problem: in the warmer months, after a medium-long journey and when the engine rpm drops to idle
(typically in traffic or when stopping at a stop sign or traffic light), the engine loses power and stalls. At that
point, you have to wait a variable amount of time before the engine can restart, and then you have to maintain a high
rpm (2000 or more) to prevent the problem from recurring.
I have a laptop with Legacy IDS Tools (official Jaguar diagnostic tools) installed, which I connected to the car via a
Mongoose cable. After downloading and clearing the errors, I drove the car for a few days and redownloaded the errors.
This is the list of errors:
Anti-lock braking system
C1277 Steering wheel angle 1 and 2 - circuit failure
Climate control module
B2426
B1263
B1242
B2796
B1262
Engine Control Module
P1000 System check not completed since last memory clear
P1582 Flight recorder data is stored
P0191 Fuel rail presssure sensor circuit range/performance
P0306 Cylinder 6 misfire detected
P0305 Cylinder 5 misfire detected
P0304 Cylinder 4 misfire detected
P0303 Cylinder 3 misfire detected
P0302 Cylinder 2 misfire detected
P0301 Cylinder 1 misfire detected
P0300 Random misfire detected
P1313 Misfire rate catalyst damage bank 1
P1647 Heated oxygen sensor control module, bank 2 open/shorted
P1316 Misfire rate excess emissions
Audio unit
U2603
Instrument pack
U2521
B1681
U1900
U2197
U2510
Does anyone have any suggestions as to the cause of this problem or what tests to run to determine it?
Thanks in advance for your kind support.
Ist dies eine gute Frage?
