Zum Hauptinhalt wechseln
Reparaturanleitungen und Support für Autos von Mahindra & Mahindra Limited.
How fix driver side doorlock issue in TUV300 or Bolero neo
In my mahindra TUV 300 car im facing a issue in my driver side doorlock which not allowing to unlock once its getting manually lock if im driving the car after 20kmph all door lock are getting doorlock automaticallly only driver side door is not getting lock if im locking it manually it can't be open again unless i need to give my car key and open it from outside
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
There is more info needed to determine the cause.
I will assume you can unlock it with a key and open it from the outside.
I will also assume once unlocked with the key you can open it from the inside.
The question is, how do you manually lock it from the inside?
The auto lock function means there is an electric lock. Do you push a button to manually lock it, or flip a lever?
I must assume you flip a lever because the electric lock isn't working.
HOWEVER, not being able to unlock and open it from the inside means there is a mechanical issue.
Tesla doors are the only ones I have heard of the have a problem doing that with an electrical failure.
Bottom line, the mechanical issue may be preventing the electric lock/unlock from working.
The key is mechanical and is separately connected to the mechanism than the internal locker.
War diese Antwort hilfreich?
Bewertung 1
Bildinhalt anzeigen:
Bewertung 1
Antwort hinzufügen
Mohan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 14
Letzte 30 Tage: 32
Insgesamt: 379
