Zum Hauptinhalt wechseln
Die Nachfolgeversion des Nintendos 3DS. Sie ist mit größeren Bildschirmen, längerer Akkulaufzeit, höherer Pixeldichte und einem verbesserten Design ausgestattet.
Crack on midframe where the hinge is located (internet led)
my question about the current situation is: what should i do?
  • take it to a repair shop (costs 100€ from what one of the repair shops told me)
  • try to repair it myself (not that experient + shaky hands)
  • buy a case (and what would be best cost/benefit for the situation)
  • leave it as is
pictures:
i dont know for how long the crack has been there. i believe it to be for a while now but i only found out about its dangers this week.
i am a college student, so using up 100€ from savings is a huge toll on me, but im also aware of the 3ds prices so like not that expensive
thank you guys so much for your help!
for context: i have ocd and idk if im focusing too much on the problem or if the anxiety is more than valid
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
as far as im aware the rest of the nintendo has no other crack
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
I would just leave it like how it is. If it's likely that you will drop it, then buy a case so that it at least won't get worse for now.
This repair is NOT easy, so if you want to repair it, I would go to a local repair shop and ask them.
But as long as everything works and if the 3DS is closing and opening as normal, I would just leave it like this.
Please let us know if you have any questions!
War diese Antwort hilfreich?
Bewertung 2
6 Kommentare:
@dan0 the only thing ive noticed is that when i open the 3ds the clicking sound is really loud. otherwise, everything else is fine. since i usually only play at home i think its gonna be fine then, but i might just buy a case and look around for a cheaper repair shop. thank you a lot!
von
Ah then I would it like that. It’s fine! If it get worse or completely breaks, I would ask a repair shop :)!
von
hey @dan0 one last question and thank you so much for your help so far! do you think superglue would work? i wouldnt open it just put a drop of superglue on the visible crack. and also i didnt quite understand what you meant on your last comment haha on the "i would it like that" thank you so much once again!
von
Ah sorry, I meant, I would leave it like how it is now!
Hmm, I advise not to put super glue there, just leave it how it is :)! It should be fine!
von
thank you a lot!
von
1 weiteren Kommentar anzeigen
Antwort hinzufügen
Gabriel Silva wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 33
Insgesamt: 349
