Zum Hauptinhalt wechseln
Das Lenovo G510 ist ein Laptop, das von Lenovo entwickelt und 2014 als Teil der Ideapad G-Serie auf den Markt gebracht wurde.
laptop won't turn on and won't charge
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Have you noticed something strange before it happent? Maybe slow/very fast charge or something like that?
von
i don't remember it just stopped
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@mohamedkha39364 start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
You may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Mohamed Khaled wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
All Time: 181
