Zum Hauptinhalt wechseln
Reparaturanleitungen, Support-Informationen und Fehlerdiagnose für das 13-Zoll MacBook Air vom März 2024 mit dem M3 SoC von Apple. Veröffentlicht am 8. März 2024, erkennbar an der Modellnummer A3113.
showing Apple logo for a second before the screen blackout
Hello, so I received this MacBook Air and the owner said that they spilled some liquid on it a few weeks back and it stopped working, so I’ve took it apart, it didn’t show any signs of liquid damage but a screw. so the first thing I did was some scrubbing the little connector on the motherboard gently with some isopropyl alcohol.
but as I reassembled it back together and pressed the the power button, the screen turned on, displaying a Apple logo for 5 seconds before turning black even though the MacBook was still on. I’ve use an external screen, and it displayed only if when I’m charging it. Help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Did you fully remove the logic board or just look at it from the bottom side?
We don't have any guides for this model as it's almost a carbon copy of the older M2 model where you'll find these guides 2022 MacBook Air M2
Here's the explicit guide for the logic board Logic Board tauschen. I'm suspecting there's more damage on the back side.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
I’ve fully removed the logic board and looked closely to insure that there was no water damage but there doesn’t appear to be any damage to the board though
von Teilen
@johnayer59209 - How does the connectors look and are any discolored/burnt components?
I'm suspecting you still have a logic board issue. You may need to snag the schematics and board view drawings so you can trace out the logic and/or power rails. The other option would be sliding in a spare logic board to verify things.
von Teilen
They look fine in my opinion, but I did took off the shielding from the logic board and there’s some rust on the bottom left of the metal. but I think it might be a logic board issue sadly
von Teilen
Antwort hinzufügen
Fox wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 31
Insgesamt: 314
