The K-Gro PowerPro is a ridable lawnmower built for K-Mart by MTD and Murray. Released in 1997. Model numbers: 13AL452F120 (38", 12 HP) & 13AQ695H120 (46", 18 HP).
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
The obvious conclusion is that you are not in neutral (N). To evidence this:
* STOP THE ENGINE.
* have the vehicle on flat and stable ground.
* put the vehicle in N
* Release the brake, and try to push/roll the vehicle forward.
If there is significant resistance, the drive train is certainly connected to the engine. Do this, report your findings
So there is significant resistance when I try to pupush the mower when in “neutral”…. I figured it was just because the tire are low….. what’s the fix if the drive train is still engaged while In neutral?
* STOP THE ENGINE.
von Jade
von wade yates
