Zum Hauptinhalt wechseln
3DS XL with drift, sound, responsiveness and random shutdown issues
Hello,
I have a problem(s) with a 3ds xl.
When I power on, sometime I have the starting sound, sometime I havent.
Most of the time after a "normal" start there is no sound and it's comes with a drift of the cursor on the bottom screen and, in this case, joystick buttons and touchscreen don't react to any action. A few time, no sound, no drift and no reaction to any button.
Sometimes it's drifting but can be stop it with the control pad by pressing in the opposite direction.
Sometimes, after a few (random) seconds, the console shutdown silently.
I change the joystick and the touchscreen but it don't get better.
After changing the touchscreen I was able to calibrate the touchscreen and the joystick one time but since, it's doesn't work.
I am able to get into the safe mode with (L) + (R) + (A) + (D-Pad Up) buttons hold at start, each time with sound but most of the time unresponsive touchscreen/buttons.
Sometime , the touchscreen is responding when the drift stop.
One thing is working every time, power on/off button.
Try to understand the relationship between the sound, the drift, touchscreen/buttons unresponsive and the shutdown problem...
Video without shutting down : https://www.youtube.com/watch?v=x4QOZZce...
Thanks.
Update (11/17/25)
Here is a picture of the little piece on the upper right corner next to dpad.
Seems pretty rusted on the picture but it's not the case, just bad quality picture even if the color of the little piece is pretty accurate.
Thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi!
Is the 3DS modded?? And did you spilled liquid on it??
I think it’s the motherboard that having issues here. I would try another motherboard and see if that solves it.
Guide: Nintendo 3DS XL Hauptplatine Austausch
Those can be found at AliExpress as example. I think there are multiple issues with the motherboard atm.
Please let us know how it goes!
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Thanks for your post.
I dont know the history of this 3ds but it doesnt seem modded (select on power on give nothing). For the liquid, I will dismount the motherboard completly to inspect it more closely. On the top upper right of the motherboard there is a little piece white and pink. The one in my 3ds doesnt look as white, maybe a sign of liquid in the past. The components around seems pretty clean.
von
I added a picture of this piece in my initial question.
von
Hi!
Yeah, that is a indicator that means when liquid reached the motherboard. So will clean everything first with isopropyl alcohol! Otherwise, replacing the motherboard is an option!
Please let me know if you have any questions!
von
Antwort hinzufügen
Eloic wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 194
