Zum Hauptinhalt wechseln
Plantronics Bluetooth Headset. Can be identified by the model number B8200 on the inside of the headband near the left earpiece, the letters "PLT" on both the outside of the right earpiece and on the tag protruding from the side of the headband.
There is this annoying sound that keeps beeping when I move my head
I cannot find a way to stop it from doing it.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I believe I am experiencing the same problem. For me, the noise cancelation switch on the left side appears to be failing or has a loose connection. Try sliding this to various positions to see if your problem reproduces. Mine is mostly stable with cancelation at Max, but at mid or off positions any motion produces the beep you're describing.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Simon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 100
