Zum Hauptinhalt wechseln
The GeForce GTX 750 is a mid-range graphics card by NVIDIA, launched on February 18th, 2014. Built on the 28 nm process, and based on the GM107 graphics processor, in its GM107-300-A2 variant, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_0.
HDMI is no longer working on the GeForce GTX 750
HDMI no longer works how do i repair it
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
So are you getting a signal out of the other ports? As an example if the DisplayPort connection is working maybe it's just easier getting a converter for it.
If you want to get the HDMI port working on the board does it look damaged in anyway? Often systems are pushed back on a desk or floor compressing the cable which in turn stresses the port connector. This might only need a new connector.
If you have a good diagram of the HDMI ports connection on the logic board have you tried just checking continuity between the external collection side and the solder joint inside of the different lines. Then when powered are you able to test the signals probing the logic boards port solder joints comparing it to a second board using a DVM and maybe an oscilloscope to visualize the signal.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Antoj wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 183
