Zum Hauptinhalt wechseln
Die zehnte Auflage von Samsungs Flaggschiff kam im März 2019 mit Android 9.0 (Pie) auf den Markt.
My Samsung continuously reboots until battery dies. Why?
My Galaxy S10 runs just fine until I have to reboot it. After I reboot, it continuously reboots until the battery dies. Then I start it up and it runs fine again until I have to reboot it. Why would it do this and how do I fix it?
Ist dies eine gute Frage?
Bewertung 0
8 Kommentare:
Hi @sshangreaujr
Why do you have to reboot the phone?
Does the problem occur if you start the phone in safe mode?
von
Updates, a weekly restart, whatever.
Whichever mode I boot into, the phone runs just fine unless/until I have to reboot. Then it continuously reboots until the battery dies. (I put in in the fridge when it does that so it won't get too hot.) When I start it up again, the cycle starts over. Runs fine until a reboot then just like poor, old Michael Finnegan, the reboot loop begins again. :-)
von
@sshangreaujr
You said " Runs fine until a reboot...."
If it keeps on rebooting until the battery dies, how do you get it to fully boot and work OK?
von
@jayeff
After the phone dies and I start it back up, it works just fine until a reboot.
von
@sshangreaujr
Don't you have to fully charge the battery first?
Instead of allowing a reboot what happens if you turn off the phone in the normal manner first and then try turning it on?
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
1 Antwort
The most common cause is a settings or system issue, such as enabling the "Auto Restart" feature, or a glitch in apps or the system itself. Sometimes, the cause is hardware-related, such as the battery or motherboard.
  1. 🔎 Possible Causes of Continuous Restarts
- Auto Restart Enabled: Samsung devices have an "Auto Restart" option within Device Care. If enabled, the phone may restart periodically without notification.
- Corrupted Apps or Software: An incompatible or faulty app may cause frequent restarts.
- Incomplete or Corrupted System Update: If a system update is incomplete or an error occurs during installation, it may result in continuous restarts.
- Battery or Hardware Issues: A damaged battery or motherboard/memory problems may cause restarts until the battery is depleted.
- Overheating: High phone temperatures may force the system to restart to protect the components.
  1. 🛠️ Practical Steps for Diagnosis and Resolution
- Disable Auto-Restart:
- Go to Settings > Device Care > Auto-Optimization > Auto-Restart, then disable the option.
- Boot in Safe Mode: This helps you determine if the problem is caused by a third-party app. If the restart stops in Safe Mode, the issue is likely with one of your installed apps.
- Update System and Apps: Ensure your phone is running the latest official version.
- Clear Cache Partition: This may resolve temporary system issues.
- Check Battery and Temperature: If you notice your phone overheating or the battery draining quickly, you may need to check or replace the battery.
- Factory Reset: As a last resort if the previous steps fail, but be sure to back up your data first.
- Consult a Service Center: If the problem persists after all these steps, the issue is likely hardware-related and requires professional inspection.
📌 Summary: Constant restarting is often caused by a settings or software glitch, but if it persists even after a factory reset or in Safe Mode, the problem may be with the battery or motherboard. I recommend starting with the simple steps (disabling automatic restarts, entering Safe Mode, updating the system), and if the problem persists, then visit an authorized service center.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
anyone can search google ai
von
Antwort hinzufügen
Steve wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 54
Insgesamt: 154
