Zum Hauptinhalt wechseln
Der 5-türige Explorer und sein Begleitmodell, der Mercury Mountaineer, wurden für das Modelljahr 2002 komplett überarbeitet und erhielten ein ähnliches Erscheinungsbild wie sein großer Bruder, der Ford Expedition.
2004 Ford explorer 2 bad tires, service engine soon? Brake light too n
Im helping my sister who basically just drives a car , single mom living on fixd income recieves no other helps hard to take car in shop - she doesn't drive but to grocery store and short like trips , had oil change bout 4-5 months ago , needs 2 tires and was saving up to replace tires when next service engine light pop on ,she said about month ago she could really hear alot more squeaks and as if her car was not as tight of a ride ..her words are ( like an important bolt came loose or fallen off ) bc it literally over nite became so loud going over speed bumps. Could this be from needing tires replaced or could it be in fact something broken , any body have questions maybe has some idea of what im trying but horribly bad description SORRY!
NEXT ,SHE NOTICED THAT COUPLE DAYS AGO HER BRAKES STARTED GRINDING NOT ALOT , NOT ALL THE TIME BUT NEXT DAY HER BRAKE LIGHT POP ON THE DASH , SO WE HAVE ENGINE N BRAKE N TIRES IN NEED OF CHECK UP , BUT SHE IS LIVING ON FIXD INCOME AND BARELY STRETCHES THIS THRU MONTH SO IT IS VERY MUCH WELCOME ANY AND ALL SUGGESTIONS ,
MINE WERE TO GET A COUPLE OF USED TIRES PUT ON , CHECK BRAKE FLUID ~ WHAT ARE THE SYMPTOMS OF LOW BRAKE FLUID ~ IF LIGHT JUST GONE ON ...COULD IT BE AS SIMPLE AS TOPPING OFF BRAKE FLUID THATS ALL !?
TIRES REPLACED ~ WOULD THIS QUIET THE DRIVE WHEN ALL TIRES ARE AIRED TO PROPER ...
ANYBODY KNOW IF THE CHECK ENGINE SOON BE LOW ON FLUIDS , ALSO SHE STATES THAT ITS NOT TRADITUONAL OIL DIP STICK / TOP OFF EASY !?? SHE SAYS ITZ LOCATED UNDER NEATH AND HAS NO IDEA HOW TO CHECK THIS ...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@tagaryu you got a lot going on here. The tires will not have anything to do with the service engine light or the brakes. The noise maybe, but we would need to hear the noise. From your description, this sounds more like an issue with the struts and /or other suspension parts
The brake light coming on is worrisome. Yes, start by checking the brake fluid level. A low fluid level would not cause the brakes to make a noise. Worn brakes pads or seized calipers can be the cause for that. Unless you are mechanically inclined, you really should try and find someone that can assist your sister with her vehicle. All we can offer here is some remote assistance but you still need someone to do the actual work.
Here are some of the manuals that you may need to look at things a bit closer. 2005 OWNERS MANUALBRAKE BOOSTERFRONT DISCREAR DISCHYDRAULIC BRAKESUSPENSION SYSTEMFRONT SUSPENSION 4X2
No worries, there will not be a test on this :-) Just something for you to look at and possibly compare it to what you find, when you look at your sisters Explorer. Now, you can also take pictures of what you encounter and post those with your question. That way we can see what you see and hopefully guide you further. The same guide will also allow you to post small videos of what you find out. Bilder zu einer vorhandenen Frage hinzufügen
It might also help if we know the geographical area, just something like State and nearest big city. That might help us to possibly find more resources to assist you as much as we can.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Taga RYU wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 24
Insgesamt: 142
