Zum Hauptinhalt wechseln
Repair information for LG ovens, ranges, and stoves.
help with lg orifice sizes
Trying to convert LG stove to LP..... I have many spare orifices that might/should work. LG identifies the orifices by letter and location....EX: for LP, Broiler is "D".
Anyone aware of a list or chart that shows the actual size of LG orifices with the corresponding location letter? Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Hi @geezo
What is the model number of the stove?
von
LG Stove model lrg3095sw / 00 THANKS JAYEFF!!!!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi @geezo
Here's the service manual
On p.43 of 79 (Sect 5-2 in manual) there a table showing the LP gas orifice code numbers and below that the burner layout diagram. (On p.44 it shows the Natural Gas orifice code numbers)
The complete conversion procedure starts on p.42.
Unfortunately it doesn't specify the actual size of the LP orifices, just their code number
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks again Jayeff. The doc will be extremely helpful! It shows the btu's for each orifice code, which should/maybe? indicate orifice diameter. Thanks again!!
von
@geezo
See if this helps
von
Antwort hinzufügen
Geezo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 142
