Zum Hauptinhalt wechseln
Eine Unibody Aluminium-Serie des Mac Mini, identifizierbar durch die Modellnummer A1347. Umfasst die Modelle ab Mitte 2010 bis zu dem derzeit verkauften Modell von 2018.
872 Fragen Alle anzeigen
Mac mini 2010 won't boot
My Mac mini 2010 (a1347 sn C07CVGNDD6H) will not boot. On power up, the mini will sound the apple chime but the everything appears to stop at the grey screen. No apple logo, question marks etc... Just a grey screen.
The power light on the front of the unit is luminated as it should.
I thought perhaps the he'd was faulty, so I replaced with an ssd (thought I'd upgrade anyway) but the same problem remains. I have also tried to boot for the DVD - pressing the 'c' button on startup. The DVD appears to run and then ejects after a min or two. Any ideas?
Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Try disconnecting the hard drive and then booting from your DVD. If this works, replace the hard drive.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for the suggestion. The Mac mini doesn't seem to recognize the USB keyboard - as a result the keyboard commands are useless, and i can't get the mini to boot from the DVD.
Is there any other way I can't get the mini to boot via the DVD.
von
Which disc are you trying to boot from? The Mac Mini 2010 will only boot from a disc that is OS X 10.6.4 Snow Leopard or later?
If so then try the steps below.
Reset PRAM Hold Apple+Option+P+R keys at startup
Reset SMC. Shut down the computer. Unplug the computer's power cord. Wait fifteen seconds. Attach the computer's power cord. Wait five seconds, then press the power button to turn on the computer.
Update
Is that the OEM disc you received with the machine?
If not that is why it wont boot.
You could put the Mini hard drive in another machine that can boot to 10.6.3 install the OS and update it and put it back in the mini and it will work (If the OS version is the issue.)
Update
I just saw your response above regarding USB. Can you not get to startup manager?
Hold Option key at startup and you should see the mouse pointer on the screen if no bootable drives are present.
Bewertung 0
2 Kommentare:
The disc is OS 10.6.3
von
I only have the Mac OS X 10.6.3 and the Applications Disc. There appears to be no power to the keyboard, and so I cannot initiate startup manager. I've plugged in the LAN cable and checked the network, via my iPad, to see if the ip address shows up, but there is nothing showing. I don't have access to a second Mac or a PC.
von
Antwort hinzufügen
James wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 7,638
