Where exactly is the Vapor Chamber inside the Pixel 10 Pro?
As fas as i can see there is no copper or graphite vapour chamber near the battery recess area , ?
Ist dies eine gute Frage?
There's a slightly thicker than copper foil sheet of copper attached to the back side of the chassis. It partially covers the area occupied by the battery and main board beginning from the top about center of the triple camera system and ends at about the top of the fingerprint sensor. I happen to have the front display removed on my old phone which two asurion repair facilities couldn't fix after the first one made the display completely unusable, touch and partial display was still working before the repair and the unit had no visible physical damage so I'm investigating the possibility that the opposite side of the display cable might have partially disconnected but ifixit has no shots of the underside of the main board so for a moment I considered removing this copper before noticing your question.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 86
Insgesamt: 209
