Zum Hauptinhalt wechseln
2.3L 4cyl or 3.0L V6, 6th Generation
My car wont start after ive done replaced the fuel pump
the shop told me that the fuel pump was the cause of my car stalling out randomly on the street or expressway. ive been told about relays and also the ignition switch thats been service by the dealer that was on recall. they had told me while i was there that there was a problem with the switch that someone else had performed service to it but not prpoerly and i just wanted to make sure that wasnt the problem. in their words the part would be like 500 dollars and it keeps my car in park when the key is removed
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Part of the problem is that you have multiple people working on your car, yet no one truly *fixing* the root cause of the stalling. Intermittent problems are a mechanic's worst nightmare which is why most of them will replace a part and send you down the road, hoping their best educated guess actually fixed something.
So let's start with the basics. Can you connect a fuel pressure gauge to the engine and check the actual pressure? The pump might be new but that does not mean the fuel pressure is getting to the engine.
This would be my starting point.
BILL
War diese Antwort hilfreich?
Bewertung 1
Keep an eye on making sure the fuel pump was connected in the right direction, b/c I had a friend who's pump was connected backwards.
Bewertung 0
I had an issue similar the end culprit was the main relay under the dash. I took a multimeter and tested the wires by the fuel pump to figure this out.does it get enough voltage to run properly. or at all for a bit when you hit a bump. I took it out and fixed the relay myself by resoldering the cracked solder joints on the board for it. Hope this helps
Bewertung 0
Antwort hinzufügen
lavell quuinn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 41
Insgesamt: 8,652
