Zum Hauptinhalt wechseln
The RCA 22” DECK215R is a full HDTV with model number M215HW03. Repair of this device requires special, nonconductive tools.
Why won’t the dvd player work
it won’t read the dvd in the slot. It will say no disc
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @makaylabarlow
Can you hear or check if the dvd disc is spinning after it has been inserted?
If you can't hear it, note the position of the label on the disc before inserting it e.g. writing on the label the correct way or upside down etc when looking at the disc being inserted and then after it fails to read, eject the disc and check if the label is still in the same position or not. If it has moved this indicates that the disc has been spinning
If the disc has been spinning, try cleaning the laser lens (examples only) in the disc drive and check if that resolves the problem.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Makayla Barlow wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 24
