Zum Hauptinhalt wechseln
Green screen without any damage at all
For some reason one day my screen had a green line out of nowhere didn't took it that serious then some days later as I was using it 80% of the screen became green as well but u can still see it normally just that now it has a green tone
Ist dies eine gute Frage?
Bewertung 0
3 Kommentare
@luisalejandro sounds like an issue with your LCD screen. Connect an external monitor and let us know if that displays correctly. If so, then the issue is most likely your LCD screen. Yes, this can happen from one minute to the next without any prior warning sign.
von
@oldturkey03 I already plugged in an external monitor and no signs of the green it's also not just a block of green u can still see image on it still
von
@luisalejandro Does the angle that the lid is open have any effect on the green tint? That would indicate a flex/cabling issue.
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You'll want to determine if it's the display itself or your GPU that's at fault here. The easiest way to do that is to plug in an external monitor. If the monitor exhibits the same symptoms, your GPU is having issues; if not, you may need to replace the screen.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Luis Alejandro wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 166
