Zum Hauptinhalt wechseln
The first generation Honda CRV, produced from 1995 to 2001.
Alternator belt replacement trouble
How is the belt supposed to be taken off cause it doesn’t have the square hole to put a serpentine belt remover tool to release the tension
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@riflelover that is correct. It should have an adjusting bolt for the idler pulley. Loosen the idler pulley bracket bolt and then loosen the adjusting bolt. That will decrease the tension on the serpentine belt and you can then remove the belt.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
When I turned the silver bolt all it did was rotate the belt though?
von
@riflelover sounds like you are just turning the idler pulley without releasing the tension. You will need to do it in this order " Loosen the idler pulley bracket bolt and then loosen the adjusting bolt"
von
Antwort hinzufügen
rifle Lover wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 79
