Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W5 5.1 Megapixel
11 Fragen Alle anzeigen
Can't open battery compartment
I haven't used my Sony dsc-w5 for several years. I am now unable to open the battery comparment. I suspect the battery has leaked and corroded the latch from the inside. How can I open the latch without damaging it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
charles, you could try and soak the corner with the battery door in a backing powder solution, and/or use a sprayer to try and spray some around the corners. Also, a toothbrush scrubbing might get it loosened. If you soak it, just place that particular corner in a solution, not the whole camera. The only other way is to disassemble the camera, the attached images may help you with that task. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
charles wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,970
