Why isn’t my ps3 working
I bought a second hand ps3, when I try to use it my tv says it doesn’t have a signal, I’ve tried resetting it, updating my tv, using a different HDMI cable and still nothing. I’ve tried all the troubleshooting I can think of and it still has no signal. Tv finally recognized the ps3 but had no picture and still said no signal, tried trouble shooting from there and nothing still. What’s the issue?
Ist dies eine gute Frage?
2 Kommentare
Hi!
Could be the HDMI IC or the HDMI port.
Can you share a picture with us regarding the HDMI port? Does this one still look fine?
Did you tried to use the AV cables? Will do this first and see if it will display anything.
Does safemode work btw? Will try this first as well.
Thank you!
von koppie007
Hi, the HDMI ports work fine, as I’m able to run my ps5 with no issues at all from all of them. I don’t have the AV cables and none lying around. My tv is a Samsung smart tv (an 8series from memory) and only has 2 ports, 1 yellow and I believe 1 white if that means anything. I’m not able to bring up safe mode. Thinking of just sending it back and claiming warranty
von AsherW
