Zum Hauptinhalt wechseln
1,8 GHz Dual-Core Intel Core i5 (Turbo Boost bis 2,8 GHz) mit 3 MB geteiltem L3-Cache
371 Fragen Alle anzeigen
Can I upgrade the ssd of the mba 2012
hi may i know for the latest mba2012 we can upgrade the 128gb ssd to 256 or 512 gb ssd ourselve? and how about the macbook pro retina 2012 for the same questions from 256gb to 512 gb ssd?
2. if yes then can u recommend what brand of ssd we should get and anything we need to take notice before we buy the ssd?
Thanks and best regards : )
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hey!
The MacBook Air and the MacBook Pro Retina both use custom connectors.
There have been fitting SSDs for older MacBook Airs around, but Apple changed the design of the connector with the 2012 model. You should also note that the SSDs of the MacBook Air and the MacBook Pro Retina are not interchangeable.
Chances are however good that there will be compatible drives for both machines in the coming months.
Long story short: Currently NO, in a few months PROBABLY YES.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Thanks senthor for ur good info!!!
von
Thanks, good info for me too.
von
OWC are now selling SSDs for the newest MBAs! Check out this link: http://eshop.macsales.com/shop/SSD/OWC/A....
If the link doesn't work, google OWC for more info. Hopefully, OWC can provide upgradeable SSDs for the MBPRs!!
Bewertung 4
Its a REPLACEMENT drive. There are external adapters/housing to use the SSD module that you remove as an external drive (super fast one). Probably worth it for a 128GB SSD class usb 3.0 external disk that fits in your pocket. OWC also makes that adapter (part of a kit too).
Bewertung 0
Antwort hinzufügen
lsgan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 43,242
