Zum Hauptinhalt wechseln
TUF Gaming Laptop (Best Buy Intex chip model) with i7, GTX4070, 15" screen.
Gpu fans And Cpu fans overspeeding
My laptop is vibrating problem comes pls any problem tell that
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hi!
Is vibrating problems just that the laptop is loud and vibrating, or is this causing additional problems?
Please check that all your drivers, firmware, BIOS and windows is all up to date. You can find your laptop specific drivers on ASUS website.
Please check if your fans are dusty. This can cause them to ramp up a lot more. You can clean them by opening the lower chassis of the laptop, and then using a small brush, pressured air, and/or a vacuum on lower settings to clean of the dust (having an unpowered fan spinning a lot is not recommended, keep a finger on the fan to keep it from spinning).
Check if you have or can change any fan curve settings either in BIOS, or in you ASUS specific software.
Do note, if you are using a high/maximum performance power profile, then ones fans tend to ramp up much more than other power profiles.
Good luck,
Cheers
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
Updated drivers and Bios. I cleaned Also fans but gpu and cpu fans are vibration and Fans speed Noise coming.
von
@dakshthevar Is the vibrating to an unreasonable level? During load, a laptop fan can get pretty loud. Especially if a performance profile is on, then fan tends to run pretty aggressively.
Does the vibrating sound like something may be broken or damaged, if that is the case a fan could be damaged (or need re-seating).
von
Man i have the same problem as you are. I gave it to ASUS repair and they told me that work will last about a month but they suggested just hitting it (not hard, but like with a mid strength on the area above the keyboard and the area to the right of touchpad. I swear it works, maybe not from the first time, but for me it surely works. Im not joking if u r suggesting that im trying to make u brake ur laptop.
von
Antwort hinzufügen
DakshThevar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 162
