How do I fix the stick drift
My joysticks isn't responding as it should
Ist dies eine gute Frage?
Hi!
This can be due to dirt and grime build up.Try cleaning the joystick.
Here is cleaning instructions from the Troubleshooting page:
Dirty Joystick Modules
Through everyday use a joystick can collect dirt, grime, and crumbs which can become lodged in components. This can make the controller less responsive to inputs or falsely respond to no input due to the buildup. To try and fix this try cleaning the area around the joysticks using canned air or a bristle brush/microfiber cloth. This will hopefully clean any debris causing issues.
If this doesn't work, then it is likely that the joystick is worn out (especially if it is old).
In that case, you can follow this guide to replace the joystick: GameSir G7 SE Joystick Module Ersatz
Good luck,
Cheers
War diese Antwort hilfreich?
Setting the frequency to 1000Hz can cause that fault
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 73
Insgesamt: 456
