Zum Hauptinhalt wechseln
The Asus TUF Gaming A17 FA506IC is a gaming laptop released by Asus in 2021. It houses an eight-core AMD Ryzen 7 4800H "Renoir" processor with 16GB of RAM and a 1Nvidia GeForce GTX 1660 Ti GPU.
Wifi disappears from the laptop
The wifi stops working on this laptop. It works for a few hours then completely disappears with no option to connect to wifi anymore. Updated drivers, disabled none working parts and tried everything. Does anyone have a fix for this?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hi @adamlorains
When you say "...WiFi stops working..." do you mean that it turns off or that it can't detect and connect to any WiFi networks again?
What is the status of the WLAN adapter in Device Manager when the WiFI stops working?
Go to Device Manager→ Network Adapters → right click on MediaTek WLAN device entry → Properties → General tab - view Device status box
Also check Device Manager→ Network Adapters → right click on MediaTek WLAN device entry → Properties → Power Management tab that the setting "Allow the computer to turn off this device to save power" is NOT checked
Presumably it works OK for a while again by restarting the laptop?
War diese Antwort hilfreich?
Bewertung 0
Well you can try the following:
  • Set Wireless to Maximum Performance
  • Disable Fast Startup (critical)
  • When Wi-Fi disappears, check Device Manager
  • Reinstall the OEM Wi-Fi driver (not Windows Update)
Bewertung 0
Antwort hinzufügen
Adam Lorains wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 52
Insgesamt: 220
