Zum Hauptinhalt wechseln
A new version of the Galaxy Tab A 10.1 was announced in February 2019, with Android 9.0 Pie (upgradable to Android 10 and 11), the Exynos 7904 chipset and an IPS display with an unchanged resolution. The rear flash is removed, S-Pen support is dropped and the battery is smaller, while the front camera is upgraded to 5 MP and the speakers are now stereo. Models numbers: SM-T515 & SM-T510.
Wie repariere ich Wasser schaden?
Mein Samsung galaxy tab A ist vor ca. 2 Monaten nass geworden. Und ging seitdem nicht mehr an
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Wie nass?
Hat etwas Regen abbekommen oder ist in die Badewanne gefallen?
War diese Antwort hilfreich?
Bewertung 0
@danieltsch33446 you will need to treat it like any other water immersed device.
The very first step I would take is to disassemble your tablet. Since iFixit does not yet have a guide for this tablet, use the Samsung SM T515 Service Manual (sorry, I only have an English copy) to work on it. Page 58 and on will show you how to disassemble it. Of course, you can also try to find some appropriate YouTube videos etc. Remove the main board and the charging board (Sub_PBA). You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the boards.
Take a close look at all components and connectors to assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are pertinent to your tablet as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. It would of course be best to get it ultrasonically cleaned.
After that, reassemble your tablet and re-evaluate. Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
Once you have the boards cleaned and your tablet re-assembled but it still does not power on, you can use the same service manual for the troubleshooting. Follow the "No Power" flowchart on page number 72. If you have any trouble with that or feel like this may be a bit to complex, let us know and we can try help you further. In that case, we would need to see your circuit boards. Post some well focused pictures (front and back) of your circuit boards with your question. That way we can see what you see.
Let us know what you find out.
Translation
@danieltsch33446 Du musst es wie jedes andere Gerät behandeln, das ins Wasser gefallen ist.
Als Erstes würde ich dein Tablet auseinanderbauen. Da es bei iFixit noch keine Anleitung für dieses Tablet gibt, kannst du das Samsung SM T515 Service Manual (sorry, ich hab nur eine englische Version) als Vorlage nehmen. Auf Seite 58 und den folgenden Seiten wird gezeigt, wie du es auseinanderbaust. Natürlich kannst du auch versuchen, geeignete YouTube-Videos usw. zu finden. Entferne die Hauptplatine und die Ladeplatine (Sub_PBA). Du musst alle EMI-Abschirmungen entfernen. Wenn du die Abschirmungen nicht entfernst, reinigst du die Platinen nicht.
Schau dir alle Komponenten und Anschlüsse genau an, um den Schaden zu beurteilen. Achte auf starke Korrosion, überprüfe die Stifte in den Anschlüssen usw. Schau dir alle Anschlüsse sowie die Kabelenden an. Sobald du grobe Verschmutzungen entfernt hast, nimm 90 %igen Isopropylalkohol und reinige deine Teile noch einmal. Für eine ordentliche Reinigung kannst du [diese Anleitung|5825|verwenden]. Sie wurde für ein Apple iPhone 3G geschrieben, aber alle Schritte passen auch für dein Tablet. Ich kann gar nicht genug betonen, wie wichtig eine gute Reinigung ist, also mach das immer wieder und tausche den Alkohol nach jeder Reinigung aus. Am besten wäre natürlich eine Ultraschallreinigung.
Bau danach dein Tablet wieder zusammen und überprüf es nochmal. Vergiss nicht, den Akku zu ersetzen. Das ist ein Muss und keine Option. Wenn du das jetzt nicht machst, wird es nicht funktionieren.
Wenn du die Platinen gereinigt und dein Tablet wieder zusammengebaut hast, es sich aber immer noch nicht einschalten lässt, kannst du dasselbe Servicehandbuch zur Fehlerbehebung verwenden. Folge dem Flussdiagramm „Keine Stromversorgung“ auf Seite 72. Wenn du dabei Probleme hast oder dir das zu kompliziert erscheint, lass es uns wissen, dann versuchen wir, dir weiterzuhelfen. In diesem Fall müssten wir deine Leiterplatten sehen. Schick uns ein paar gut fokussierte Fotos (Vorder- und Rückseite) deiner Leiterplatten zusammen mit deiner Frage. So können wir sehen, was du siehst. https://de.ifixit.com/Anleitung/Bilder+z...
Lass uns wissen, was du herausfindest.
Bewertung 0
Antwort hinzufügen
Daniel Tschechowitsch wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 29
