How to repair motherboard
Ist dies eine gute Frage?
Hi!
If you want to replace your motherboard, then this guide will show you how to get your phone open: Realme 7i Screen Replacement
Then you'll have to do some guess work with how to replace the motherboard, taking off screws and fragile connectors. But it is a start at least.
If that does not answer your question, then please respond with more details.
Good luck,
cheers
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 29
Insgesamt: 49
Ummm... it really depends on what needs repaired. Do you know? If so, that would help. And do you know what broke it? If it's water damage, you'd probably be better off replacing the motherboard. Otherwise, you might be able to replace a component, but again, that depends on what's broken.
von Fixer of Stuff
