Zum Hauptinhalt wechseln
Eine dritte Version des Controllers wurde im November 2020 zusammen mit der Xbox Series X und Series S veröffentlicht. Dieser Controller ist abwärtskompatibel mit früheren Xbox One-Konsolen und PCs.
Xbox button light flashes only when held down, will not turn on
Controller less than 6 mo old.
I use rechargeable AA batteries.
When pressing the Xbox button once, the light comes on and turns off immediately.
When holding the button, the light blinks repeatedly on and off in ~1 second intervals.
I cannot get the controller to turn on and connect to my original Xbox One. I have not had this problem until recently. The problem is inconsistent--sometimes the controller will power on after a few seconds of flashing.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I can't believe that Microsoft STILL doesn't use built-in batteries! Sure, they're a pain to replace, but rechargeable batteries can also be a pain. I mean, you're always taking them out to recharge them, and in a lot of cases, the device you're powering isn't exactly designed for quick battery changing. Like a flashlight. With a lot of those, you have to unscrew the button cap, then take out a battery case, and finally pry the batteries out. If anything, a company could at LEAST make rechargeable batteries last at least as long as regular ones. Will any company do this? Probably not. I know it's technically possible. A very compact lithium-ion battery can power a Joy-Con for about as long as two AA batteries can power one of my Wii remotes. So why doesn't anyone do something like that with a general-purpose rechargeable battery?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi!
What happens if you just put normal batteries in, does it work?
If not, I would return it. You should have warranty on it if they are just 6 Months old.
It’s probably the best thing to do now..
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
I tried a new set of rechargeable batteries. That worked! Must be faulty batteries.
von
I suppose you tried recharging the other batteries? I would test those batteries in another device, for example, a flashlight. That way, if your controller starts failing again, you know for sure if it's the new batteries or the controller.
von
Yes and otherwise I recommend to stay with the new batteries :)! Have a good one!
von
You might actually want to test the batteries in a device that only uses one battery, or else use a battery tester. That way, you know if it's one battery or both that's bad.
von
Oh, and you might be wondering where you might find such a device. Some flashlights only use one battery, but you might find it easier to find a battery powered wall clock. On the other hand, those are no doubt designed to consume minimal power, so for testing purposes, you'd be better off with a more power-hungry device like the aforementioned flashlight. Battery testers can be found online (without a doubt) and in some battery storage cases.
von
Antwort hinzufügen
Jacob Dziubek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 59
Insgesamt: 212
