Magsafe and usb c ports not working
Ist dies eine gute Frage?
If both MagSafe and USB-C ports aren’t working, start with basic checks: try a different charger, cable, and power outlet, and clean the ports gently using compressed air to remove dust or debris. Restart the device and reset SMC/NVRAM (for MacBooks), as power issues are often firmware-related. Check for liquid damage or bent pins in the ports. If the battery is completely drained, leave it plugged in for 30–60 minutes. When none of these work, the issue may be a faulty charging IC, logic board, or port assembly, which requires professional repair or an authorized service center inspection.
War diese Antwort hilfreich?
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 27
Insgesamt: 77
Does the system even turn on? When you lift the display up are you greeted with the red dead battery icon. There will be a point that may not show up.
Can you give us a bit more on what happened, did you drop or bang the system, have a liquid spill have a lightning storm or power outage which the system was plugged into power or network or printer.
von DanJ
