Zum Hauptinhalt wechseln
ASUS TUF A15 hinge broken, screen keeps falling down
I have an ASUS TUF Gaming A15 (2023) FA507NV.
The screen hinge area plastic is broken, and the hinge is pulling out of the plastic frame, so the screen won’t stay open and keeps falling forward.
I already:
  • Opened the laptop
  • Disconnected the battery
  • Removed the hinge area
The metal hinge itself seems fine, but the plastic housing/mount is cracked and broken.
My questions:
  1. Do I need to replace the entire back cover / screen housing, or is there another fix?
  2. Is this a common issue with this model?
  3. Where can I buy the correct replacement part?
I added photos for reference.
Thanks.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
@abdallaalsayghe without seeing it and going by your description of "the plastic housing/mount is cracked and broken" alone; Yes, you will need to replace the complete cover. Your hinges will continue to break the plastic and you will lose all stability without that. Use something like the ASUS TUF Gaming A15 (FA507R) Service Guide to work on that. Slightly different model but the task should be identical.
Your images do not show. Use this Bilder zu einer vorhandenen Frage hinzufügen to add pictures
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Abdalla Alsayghe wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 28
Letzte 30 Tage: 96
Insgesamt: 436
