Traction sensor of range
How can i fix inflate sensor
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare:
@emmanuelva68867 not quite sure which sensor you are referring to. Do you mean the Tire pressure sensor?
von
von
No, I was told on a Chevy Malibu 2016 eco-friendly that there was a transmission sensor that was like a $50 part that you could get and replaced
von
@kassandrek55166 let's try and narrow this down since there are actually a few transmission sensors as well. What is going on with your Malibu? Give us the complete symptoms.
von
Okay, when you pull up to a stoplight and the light turns green you press the gas cuddle and the RPMs do not raise the speedometer is not move. You can have the gas pedals all the way to the floor and it will not move and then about 10 to 15 seconds depending on its mood. It will kick in and you'll be able to drive the car again
von
Einen Kommentar hinzufügen
