Zum Hauptinhalt wechseln
Modellnummer A1707. Veröffentlicht im Juni 2017, erschien dieses MacBook Pro mit Kaby Lake Prozessoren mit bis zu 2,9 GHz quad-core Intel Core i7 Prozessoren, mit Turbo Boost bis zu 3,9 GHz.
MacBook Pro was dropped and now 5 keys are not working.
My Macbook was dropped and now the letters QWERT are not working. I tried reseating the keyboard cable, tried SMC and nothing is working, anyone have this happen, thank you.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
I believe this is the right video on your butterfly keyboard just in case you wanted to try removing one key to see if that helped https://www.youtube.com/watch?v=STeMeRjv...
von
Einen Kommentar hinzufügen
2 Antworten
Are the keys correctly seating in the keyboard? Is one edge higher, did you need to reseat them?
Update (01/05/26)
Maybe this will help explain things Apple’s Butterfly Keyboard Continues to Plague MacBook Owners dropping your system could have dislodged the keys which is why I was asking you about there condition.
If that is not an issue there's little to fix other than replacing the entire keyboard assembly. As it has faced trauma which has damaged it.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
This usually means physical damage to the keyboard matrix or connector from the impact. Since specific adjacent keys failed, it’s likely a cracked trace or damaged membrane. Software resets won’t help. The fix is keyboard replacement (top case on newer MacBooks) or using an external keyboard.
Bewertung 1
Antwort hinzufügen
RICH R wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 89
