Wifi speed slow, tried updating drivers but still not much help
Wifi speed very slow
Ist dies eine gute Frage?
Hi! I will be assuming you are using wireless wifi and not cable ethernet!
Please do the following:
Please answer the following:
There are some more advanced wifi tests that we can do. But I think this is a good start.
If you only are only having bad results on your laptop, especially if it's a sudden problem. Then it is likely that the wifi card in your laptop is going bad considering that you've updated your network drivers. Your wifi card can either be replaced, alternatively you can by a small usb-wifi adapter out of most electronic and general stores. Tho, it might also be a configuration on your laptop that is incorrect.
If you are having low speeds on both your laptop and another wifi device, then it is most likely either:
Please reply and we will continue to guide you through this all :)
Good luck,
Cheers
War diese Antwort hilfreich?
I had the same issue and drivers weren’t the problem at all. Turned out my router was stuck on the 2.4GHz band. Switching to 5GHz instantly doubled my speed. Worth checking if your device supports it.
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 25
Insgesamt: 100
